- Granite
- 4x4-Mega
I have a Mega 4x4 Granite WIP. I will be using this place to document the evolution of a stock Granite to a slicked out custom stunt truck...we I hope... If not... It will just be a bad @$$ Granite.
First off I was very frustrated with the stock servo saver. I could not get the darn thing to keep from sticking right or left. After much research I decided to give Hot Racing a try. I ordered SHS88H heavy sure black aluminum servo saver. I am still in the testing faze before I call this a good solid swap... I do however know I am going to have to make a slight modification to it... I can't seem to find the sweet spot between the servo gear teeth, the ss adapter, and the ss itself where the steering doesn't bind at full lock. Easy peasy fix though... I just need to grind off a corner of the ss and it will work just fine.
Next up on my plans is to get metal turnbuckles with metal ends to eliminate the steering slop and add some adjustability to the camber and toe.
Also need a set of T-Bone bumpers... Destroyed my front bumper and skid plate at the sk8 park last weekend.
