Joceton
Hey folks. Looing for some advice. The Granite 4x4 Mega that my daughter has seems to be having some issues. The Motor is getting hot on a 3300 mah NimH battery, to the point where it cannot be touched for more than a second for two. The wheels also don't seem to spin freely when the power is not engaged. With the power module attached in the truck, the front and rear wheels will not even get a full turn when I spin them before they stop spinning. If I remove the power module, the wheels will spin a bit better (maybe a full turn and a half). The spur gear seems to move freely inside the power module, and I meshed the spur gear and the motor using a thin piece of paper as a spacer.
Is this lack of free spin on the wheels normal? I wouldn't expect that the motor should get that hot either.
I have replaced the spur gear twice already, and I think this was a result of using a 2S lipo battery. I read here that the 2S is a bad idea for the stock motor, but do the spur gears go in these a lot?
