Granite mega battery
Desertrat
Arizona
I just got my Granite, when I bought it it said a 7 cell Nimh would fit without any mods, however when I went to install the battery it will not fit. Am I doing something wrong?
Walter
  2. Granite
You have to pull out the foam spacer in the back of the battery box and then it will fit.
The Granite, Vorteks and Raider (non XL) all use the short wheel base SWB chassis. The Fury uses the long wheel base LWB chassis which has a bit more room.
I can tell you with certainty that my Granite BLS came with a 7 cell NiMH (stick, not hump) battery pack and it fits just fine.
Desertrat
Arizona
Great I sent the battery back lol. I suspected taking that out but the instructions made no note of it. I didn't want to go yanking on things until I knew more about it.
Thanks
Rto_13
I had the same question, though that answer doesn't make sense to me because it wouldn't make up the inch or more space needed for the battery
Walter
  2. Granite
What doesn't make sense?
Here is the Short Wheel Base (SWB) chassis part information: (You can see where it is used on all of the new MEGA, BLS and BLX models)
http://www.arrma-rc.com/part-info2.php?partNo=AR320201
Here is the top section of the upgrade card for all the Granite models: (Note where the BLS is supplied with a 7 cell battery)
You can also look at the story board at images 23-25:
http://www.arrma-rc.com/rc-cars/latest/granite/bls/story-board
Bottom line... a 7cell NiMH stick battery does fit in the Granite or other SWB chassis based vehicles.
Walter
  2. Granite
I'll try and measure my stock 7 cell battery and let you know how big it is.
Rto_13
Okay thanks
Can you recomend a 7 cell battery that will fit?
Sorry about that whole thing, I just didn't really want to take the foam out becuase i thought it would be glued in, but it's not, so I can put it back in if needed. Thank you.
