- BigRock
- BigRock 4x4
- Granite
- Typhon 3s
Finally got my Granite all put back together. My Mega to BLX conversion is complete. Final parts I'm waiting on are a set of ZD Racing shocks from Banggood. Should be here next week. The body is from eBay that is made for a Traxxas. I had to cut the whole rear bumper off to fit the Wing and mount on. I shoogooed and drywall taped inside of the body as well. So it should last a whole lot longer than the stock body. I also added the Typhon 3s front and rear A Arms making it wider. Motor is a 3200 kv with a 16 tooth pinion. I am running BLX diffs and slipper. It's been quite the journey of converting this. Next small upgrade will probably be the Hot Racing aluminum pivot balls.
