Granite Granite - no forward or reverse motion
Goldy-9
Hi Guys,
Advice please, I have a Granite all charged up, has steering but doesn't move the red light flashes but nothing else happening. What's this likely to be?
Thanks in advance for your help.
Cheers
Goldy
Hi Guys,
Cheers
Goldy
Are you using a Nimh, or lipo battery? If using nimh, it might be on lipo mode causing low voltage cutoff.
I have checked and the esc is in Nimh mode! Note the car is fairly new and was going fine but haven't used it for a couple months.
Are the motor wires correctly plugged in?
Yes I checked that too, have also checked the battery is charged correctly and it is fully charged.
