WHats the best glue u use? I use the horizon hobby glue
Common problem running on the street at high speed, they don't last forever doing that with all the balooning.
I haven't tried to get warranty on tires because I try to save up my claims for the big stuff. You should be able to find a new set pretty cheap online. 2/$25 or 4/$50
What kills tires are water+dirt inside the tire when it has no where to escape or agressive wear. And also diff fluid weigh ussualy a tire explodes when one tire receives 100% of the power +the water and dirt trapped inside and you have a receipt for explosion. Belted tires imo don't have their place really in bashing you need to have a bit of balooning to do the stuns. Belted are more expensive and heavier by quite a bitI figured that’s what kills them. Guess i need to invest in some belted tires if i wanna go fast and make the tires last. ?
Yea it might not be worth a claim. I’ll try and get 2 at least and then get some better tires later. ??
If you went trough some water your tires were already compromised if it did not have holes on the rubber to let that water escape and tape the rims holes
You can try 10k front and rear and then try 30k front and 10k rear it all comes about personnal preferancesAhhhh. Ok. I’ll keep that in mind. It did look like the right rear tire had the most wear out of all of them. Funny thing was i rotated the tires and then the rr blew up lol. That was the RF before. The foam insert looked clean and dry. What diff oil weight works good to make sure it’s transferring power to all tires equally?
Did the tire unglued itself from the rim or it just ripped apart without pulling off from the rim?Ahhhh. Ok. I’ll keep that in mind. It did look like the right rear tire had the most wear out of all of them. Funny thing was i rotated the tires and then the rr blew up lol. That was the RF before. The foam insert looked clean and dry. What diff oil weight works good to make sure it’s transferring power to all tires equally?
I agree to a point here J. I had similar issues with my MX28 Badlands until I vented them. No more need to check the beads anymore. Used to have to glue them almost every run. They’ve held up perfectly ever since I vented them. I immediately went and vented every tire I own. Glue hasn’t been out of my toolbox since. I even bought some new glue that sits unused ???✌?Hi @Frankthetank. Chances are, your tire tore from the rim outwards. It's also important to check the bead between the wheel and rubber after each run. If the bead breaks at any point, you need to reglue it right away. Venting is good, but I have a completely sealed pair of Backflip Lp's on my Notorious 6s. If I didn't check that bead after each run, I would have lost a tire(s) a long time ago. I do the same check on my Granite. Even a little tear should be glued up. Hope this helps in the future.
It looks like it just ripped apart. There’s still rubber glued to the wheel where it came apart. I will take a look at the others to make sure they haven’t unglued.You can try 10k front and rear and then try 30k front and 10k rear it all comes about personnal preferances
Stock is 6000-7000wt i think
Maybe one side of the glue on the tire let go because it was already weaken or needed to be reglued thats why its important to keep an eye on your tires beads
GOing to sleep goodnight
I’ll take a look at all my tires today. Thanks guys for all the advice. I’ve been out of the hobby for about 10 years and I’m glad to be back tearing things up ?.
ANd the other side the tire always unglues itself from the front not from the inside
Yeah rip tire then it balooned way too much
Tire blow out happen they suck for sure at least you did not hirt or damage someone or propriety
This is why I check mine each time. Some glue on a small tear will extend the tire's life quite a bit. Jennys Rc is a great place to shop for spares.Nope, it’s still glued all the way around ?
Now for tires at least for my tiresThis is why I check mine each time. Some glue on a small tear will extend the tire's life quite a bit. Jennys Rc is a great place to shop for spares.
Yo what glue is everyone using????So i bought my granite in February of this year. Super fun and quick. Well yesterday i was doing a “speed run” and i had a tire explode at 50 mph lol. Has anyone seen this happen on their trucks? And will the send me a replacement?
https://www.amazon.com/dp/B002N507I0/ref=cm_sw_r_other_apa_i_XhDNEbR865E99Yo what glue is everyone using????
