Don mercier
Anyone have a set of 14mm hex rime and tires for sale for a granite, ill take your stock ones as long as they aren't worn too bad
This is the way to go.You can buy a set of Duratrax 3596 12mm hex and not have to use the 14mm tires and wheels.
Crimsonfancy, Do you use the Hot Racing 12mm to 17mm adapter also I know a LOT of people do? I seen the HR part number listed in this forum awhile back and its for the 6mm offset ones. I found 10mm offset ones the crazy thing is on Amazon they are cheaper then the 6mm offset.
Amazon Link:
https://www.amazon.com/Hot-Racing-1...=UTF8&qid=1547251318&sr=1-2&keywords=WH17HS01
Ebay:
https://www.ebay.com/itm/NEW-Hot-Racing-Slash-4x4-10mm-Offset-17mm-Hubs-12mm-Hex-Mount/372100223319
Yes, I do run the 6mm Hot Racing extenders and MX28 Badlands
Pistol grip are pretty nice thouI had some MT10E tires on there while they were still 14mm.
I also had Duratrax Pistol ST on there for a couple days while I had it 12mm. I liked it then. No rub.
View attachment 27008View attachment 27007
I don't want 12mm hex i like the 14mm and its cheeper to just slap on some granite rims and tires that somone don't wantYou can buy a set of Duratrax 3596 12mm hex and not have to use the 14mm tires and wheels.
