- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
So where to begin...
It all started a while ago when I saw @CrayZee_One had slammed his Granite.. so cool by the way..??
My journey began with a busted Granite body and a bag of Jenny's spares..!!
I must first apologise for this most hanus of crimes as I fitted a Traxxas part on my Arrma..???
I decided to create a sort of speed run Granite without cutting it to death, also keeping it looking as standard as possible.
Started with some parts out of my Kraton (waiting on m2c chassis for it) I used the servo and the BLX185.
In keeping with the standard look I made an esc mounting plate out of 3mm Lexan..
From there I fitted the Kraton servo, after that I decided to order some rpm arms and another motor then my crime happened...
Was already running the Hot Racing motor mount so thought I would push the pinion to the max which is 27T by the way...?
I was trying to work out the best way to lower the truck and came to the conclusion that I would make some sleeves for the shafts out of 8mm acetal/delrin..
This would shorten the shocks by 15mm lowering the car a fair amount, keeping the original springs which are now quite stiff because they are compressed so much, not ideal I know but no extra cost.
Before and after length..
