THEPISTONHEAD
Newbie question, will the ARA390288 ESC work as a stock replacement on my sons Voltage? Truck is bone stock and has a bad ESC......will the ARA390288 plug and play? Thank you in advance!
IS there any other direct replacement ESC's that will work in this truck without buying other parts? Issue 1 is the stock ESC is $50ish and issue 2 is it's out of stock everywhere.....You’ll also need a new receiver, servo (stock voltage servo is five wire and mega esc is three wire) and I’m not sure if stock motor-mega esc bullets are the same size. I put the mega motor, esc, servo and receiver from my old mega granite into a voltage over a year back and it worked well.
