ahron.reinhard
I’m hoping someone will be able to help me troubleshoot my problem as I wasn’t able to find the issue specifically in the manual or on this forum.
My son got a brand new granite voltage for Christmas and the vehicle no longer able to be turned on.
The 1800 MAH 7.2v NiMH battery pack is showing a full charge and and the remote control itself has 4 brand new AA batteries.
The remote itself turns on but immediately starts beeping red and flashing when I try to power on the vehicle itself. The vehicle light does not turn on and it will not move.
Background:
We followed the set up instructions carefully and everything seemed to be working fine until my son brought it outside in wet conditions.
I advised him against using it in the snow because even though the instructions do say it should be relatively fine in wet conditions as long as it’s not completely submerged in water, I figured it would not end well with all of the electronic components.
He took it out there anyway and after about 10 minutes it started to slow down and then it wasn’t responding to the remote at all.
We brought the vehicle back in to be dried off and then we waited about 10 minutes to plug back in the 1800 NiMH battery back. About an hour later the light was green again so we unplugged it.
Today when we came back to use it again we encountered the flashing, beeping problem. Another odd thing is even without the battery pack being plugged into the power cable, the green light turns out immediately when we plug it in into an outlet. I can’t recall if it only had a light when the battery pack was plugged into the power cable before but it seemed odd given all the issues with the vehicle itself.
Please let me know if you’re able to help.
Thank you!
Background:
Thank you!
