Voltage Granite Voltage upgrades?
Curt_digsRC
Voltage
First post here!
I've got a Fazon Voltage headed my way (for the wife actually), but I'm kind of excited to play with it myself : )
Of course, I've had to already be ordering upgrades for it before I've even got it here yet. Going to be running 2s 5400mah Lipo. I just ordered the Arrma Mega 15T 540 motor; from my web searching it looks to be about 3300kv, as opposed to the stock 20T which looks to be a 2100kv. I'm going to try it out on the stock 19t pinion and see how she goes. I'm in Alaska, so maybe in colder months could even try out the 25t pinion (with snow paddles!?).
I've seen the YouTube vid of the guy who swapped to a GoolRc 13T 540 and stock 19t pinion and seemed to run really well! My guesstimate is that the 13T 540 would be 3900kv or so, but my thinking was for long term that might be a bit too aggressive...
Was tempted to try the 12T 550, but I'm thinking the 550 series may generate too much heat for the platform, judging by some other posts here. Overall, after thinking it over, the 15T 540 seemed like the best compromise for brushed. We'll see : )
I'll post up in a few weeks when I'll be back in town and ready to play with it, first stock, then with the motor swap, hoping the $20 motor will make a nice difference. Amazing how cool these modern trucks are nowadays for $100!
GRspeed
Northern California
Granite, Voltage
Many seem to say the brushless motors from off brands work well and are consistent. It's the ESC that folks have problems with. That said, get a brushless system with wires that exit the end of the motor opposite the output shaft. It helps having to avoid modifying the chassis to accommodate.
swampguts
Granite, Voltage
Well, we have wheelies. Arrma 12T 550 and a YR 40mm fan mounted to blow through the motor compartment. The lipo did drain quicker than before, but we still got almost thirty minutes out of it. 31578Hopefully I can keep myself from messing around with it any more for a month or two.
swampguts
Granite, Voltage
Haha. It's raining now, but when he can get some grip I'll record him.
swampguts
Granite, Voltage
He didn't want to drive, and as you can see he isn't the best filmer.
swampguts
Granite, Voltage
Aaaaand I broke it. Recorded the earlier video before taking him to school, got greedy and put the nineteen tooth pinion in when I got home. Idler, spur, and differential gears are now toast. But it would hold a wheelie indefinitely for about three minutes before something internal lost teeth. Haha.
Jimmyjam
missouri
Granite, Voltage
Well, we have wheelies. Arrma 12T 550 and a YR 40mm fan mounted to blow through the motor compartment. The lipo did drain quicker than before, but we still got almost thirty minutes out of it. View attachment 31578Hopefully I can keep myself from messing around with it any more for a month or two.
Did you screw that fan down?
swampguts
Granite, Voltage
One screw, through the end of the housing for the spur gear on the out side. The motor wire clip, back of the spur cover, and the ESC hold the other three sides pretty securely in place.
Similar threads
