ArrmaGraniteState603
- Granite
Hey Guys, was running the DB fortress with 14mm hex, bought some Duratrax Hatchets and some 12MM Extenders for a wider stance and better stability. My issue is the wheel extensions AND the 12MM Hex I bought don't sit down on the drive axle as much as they should and the pin won't set inside the hex or extension. Did I order the wrong size? Seems like the hole needs to be just a tad bigger to allow the hex or extension to slide onto the pin. Help! Yes the Hatchets are a 12MM hex.
