- Granite
Still needs paint and shoe goo. But I'm loving it already.
That’s body is dope. I would go with an antique color like a light green or baby blue.
I wanted an antique baby blue, but I couldn't find it in polycarbonate. The closest was Duratrax Teal. I bought it, but it's too bold, more Notorious blue, not really vintage/faded baby blue. I've seen some videos with great antique blues, but not polycarbonate, or probably an airbrushed mix. This is perfect, but it's not polycarbonate.That’s body is dope. I would go with an antique color like a light green or baby blue.
I did mine in Tamiya PS-14.
That is a Traxxas Stampede with the Proline body mount kit https://www.prolineracing.com/performance-parts/extended-body-mounts-stampede-4x4.aspLooks phenomenal! Can you tell me more about the mounting system you are using? Is it convenient/easy, how do you like it? Where can I get it?
But for the Granite you can modify the body posts to fit these https://www.amainhobbies.com/prolin..._PyJZ0Su4uD2HUom4Ec8crPszEscYB1UaAhVvEALw_wcB you will need a dremel and a 3.5mm drill bit.
Mini Notorious. I liiiiike it!
They hold up great for bashing, every now and then one might come off so you should check them from time from to time to make sure they didn't loosen up. The Proline ones hold up better than the 3D printed ones I bought off eBay though, the ebay ones tend to crack or the threaded insert pulls out of the plastic.Thank you that's a great help! How do you like using them? Are they better for a shelf queen or do they hold up for bashing?
With stock V1/V2 Granite body mounts, the front tilts downwards quite a bit. With the new longer V3 Granite body mounts the body sits nicely. https://www.arrma-rc.com/part/ARA320606 You just have to drill new holes for the pins. The body mount platforms in the rear block the body pins. Drilling holes in the body mounts that run lengthwise rather than across the body solves the problem. A benefit to using Granite body mounts is you can still use Granite bodies from the factory.Looks phenomenal! Can you tell me more about the mounting system you are using? Is it convenient/easy, how do you like it? Where can I get it?
No pins. What are you using for a body mount system?Just did mine yesterday also! Light coat of Dark metallic Blue with black backer.
Bah, I found it, Tamiya Corsa Grey. Too late for this body, already went with a different color.That’s body is dope. I would go with an antique color like a light green or baby blue.
Where did you get the plastic pieces on the roof and the rear of the bed? Did you make those?Went with gunmetal and black. She's banged up already. At least I landed my first front flips.
Made from heat moldable plasticWhere did you get the plastic pieces on the roof and the rear of the bed? Did you make those?
How about both?That’s body is dope. I would go with an antique color like a light green or baby blue.
