Granite Granite with 4s wing mount?
martin34
  1. Notorious
Hi I want to fit the 4s outcast wing onto my granite.Could anyone post some pics of how they fitted it?Not the wing but just how you fitted the wing mount.Thanks for any pics.
It’s a direct fit . No mods needed
Thanks for the pic but I don't want the body to be above the wing.A guy sent me some pics on Facebook showing how he did his with some Dremel work but I was wandering if there was any other solutions.
Here is my install pics
wing mount is the same for all 3s and 4s rigs, you will need that and a set of front outcast body posts.. the body is sitting higher on thiers because of the factory granite mounts.. the outcast front body mounts are a direct fit and will lower the body in the rear to get the effect your after...
Thanks that's the route I am going to go?
forgot to mention the body posts on the 4s outcast mounts are larger so you will need to drill the body mounting holes out slightly... i also recommend, (but not needed) another set of front mounts as they are also a direct fit on the front of the granite...
Thanks for all the tips and advice guys.I will get the body posts ordered?
Yea I have them on there. Didn’t feel like needing to rebuild current ones. I checked jennysrc like 2x a day for two weeks and found them in stock during that time
