Granite won't go
rc138
Ive had my granite for less than 20 minutes and the wheels won't do anything. They will turn when off the ground, but as soon as there is any resistance......nothing. I haven't wrecked it or anything. I figured it's somewhere in the driveline but I'm new to all of this. Any help would be appreciated. Links to videos or a page manual.
Dustin Mustangs
Make sure your slipper is set right and check the mesh between your spur and pinion. Both procedures are in the manual if you are not familiar. Hopefully it is one of those two things because otherwise you are likely looking at a gearbox full of stripped gears. Take a peek at the other current gear and diff threads in the granite forum for more info on that.
