I just wish we could tune it and keep the diff-lock![]()
Maybe you can just remove/unplug the center Brain servo and plug the holes in the diff and fill with fluid.
That way can still use the front and rear diff lockers. That would be cool.
What did you put in the front and rear? 100k also?I put 100K in mine. BUt I totally agree, it drives so much better with oil in the diffs. I ended up doing all 3.
Good info! ThanksPut this in the center diff of your Non-Brain Nero immediately!
Took it out for the first time with 500K in the center it completely transformed the truck.
An absolute BEAST!
This truck seems to have a lot
I moved the shocks to the inner holes which helps with the binding and also gets a little more droop travel. I would like to have even more suspension travel. It seems like the arms and shafts would be able to handle more angle. I also put thinner oil in the shocks so that it does actually use the droop when you go over holes and it also keeps the rear from bucking so easy when you hit a jump. I am using this truck a lot like my Summit and the more I tweak things the more I am liking it. It's good to have something different from the crowd.
Grub screws is what I'm gonna do. With some loctite, should seal great.didn't think of putting grub screws
are those holes threaded? M3? and what length of screws are needed? I'd imagine probably no longer than 4 or 6 mm?
