Barmaleus
Hi all!
Been actively using 2 hardcase batteries with my Kraton 4S v2.5 for the past 7 months or so. Mostly forest roads, but also some gravel. I also use a dust cover.
Recently noticed there are some rocks inside the hardcase - they got in through the holes for wires. Could not get the rocks out, so had to open the battery cases. CNHL did not recommend it, but I also did not want to keep using the batteries with rocks inside.
The cases are not hard to open. Just need to be careful. Got in, removed all the small rocks. The cells were clearly damaged by rocks - but did not look critical (or am I wrong?). Assembled everything; used gorilla tape to hold everything in place. Added extra tape around the wires, Layered in different directions to make sure there is as little open space around the wires as possible. Looks pretty solid now.
@Chinahobbyline - A suggestion from customer. Use better, MUCH tighter sealing around the wire holes.
Question to everyone: how are you making sure nothing gets inside the battery case? Maybe hot glue? Or is it too hot for this application?
Thanks!
Thanks!
