Kraton Has anyone had problems with the pinion gear not staying tight on the kraton
Chop3398
Nashville
I just replace my motor on the kraton because I believe that the Motor shaft was ruined and wouldn't hold my pinion gear well I replace the motor and pinion gear and the problem is not resolved pinion gear is still slipping off shaft can anyone help me solve this problem
Kauaiguy
Kauai
Are you using locktite?Put a drop on the pinion and a little on the motor shaft.Use heat to remove.
Chop3398
Nashville
I just got a good look at the pinion gear and the set screw look like it melted inside the gear hole does that come from gear mesh being too tight
Kauaiguy
Kauai
Can you post a picture? If you didn't use locktite,the set screw will back off during use and round off the end of the setscrew.You probably need a new pinion/ setscrew.
Tink
Get a new 4mm set screw most hardware stores have them and use blue locktight
justpassedu
NewYork,NY
Make sure when screwing the set screw you are doing it on the flat part of the motor shaft , also use a dab of blue loctite on the set screw before tightening it down and yo I should have no problems again .
Vanning
Use new Loctite and use red as long as you have a soldering station to remove it later. Loctite goes bad after a while and it stops working. You have to get a new tube every so often. Keep it in a plastic sandwich bag so it stays fresh longer.
Vanning
The Kraton comes with red Loctite on the pinion screw and between the gear and shaft. You have to heat it up real hot to remove it. Even use a pinion puller if needed.
