I have mine running an 18T and it runs fine this time of year. Summer time it will overheat if running in grass WOT, but it’s fine for basic bashing.Hey all, has anyone tried a 15t or larger on the 4s outcast/kraton? Looking for feedback. Thanks!
I never ran the stock pinion, which I think is a 13T, but at 18T this thing pops wheelies at 45mph on the slightest throttle input above half throttle. Can’t get it WOT on any high grip surface. I may end up gearing back down a few teeth to be able to get more nose control.That's why I asked, I know a 16t on my kraton 6s was a major improvement over the stock 12t. Didn't know if there was improvement in a re gear on the 4s . Any feedback is appreciated!!?
No the low end does cog some on 18T so I would say the stock gearing probably has better low end punch. I do have the adjustable motor mount on all my rigs. I think 15T to 17T is probably the sweet spot.So it retained the same low end snap as before, awesome! Do you have the optional sliding mount? I was going to try a 15t with the stock fixed mount for now.
I was running a 15t and felt it needed just a little bit more. This morning I changed to a 17t and it's FAST ? wheelies no problem. It cogs a little on start but no worse than it did on the 15t.
It does.Thank you very much for the feedback! Does the 17t require the adjustable motor mount?
Thank you very much for the feedback! I'm going to try the 15t first, then the 17t.
I'm going to make a video of my K4S at WOT with a 15t pinion. Just for you ?I’m actually heading back down in pinion. I had been running 18T and recently stepped down to 15T and still can’t go WOT without it flipping backwards. Hoping 14T might allow me to get to WOT in an open field.
I would LOVE to be able to get mine to WOT so any input you can give is much appreciated. There is snow coming down here, so I don't think I can get enough traction anywhere today to test anything, but looks like this Sunday is going to be in the 40s again.I'm going to make a video of my K4S at WOT with a 15t pinion. Just for you ?
I just accelerate gradually until it's wide open. If the front comes up at that point it's because wind got under it.I would LOVE to be able to get mine to WOT so any input you can give is much appreciated. There is snow coming down here, so I don't think I can get enough traction anywhere today to test anything, but looks like this Sunday is going to be in the 40s again.
There is never a point I can get over 3/4 throttle without it backflipping. I tried a huge soccer field at the park. It’s like 9 soccer fields in a square. Huge flat perfect field. From one corner to the other, I tried at least three times to get it WOT and would get 3/4 there and anything more and it would wheelie. No way to keep the nose down. Maybe the wing is to blame? I can try without it next time I’m out. ??I just accelerate gradually until it's wide open. If the front comes up at that point it's because wind got under it.
