- Montgomery county PA
- Granite
- Kraton 6s
- Notorious
- Typhon 6s
Okay so I bought the dx5c so I could consolidate on my radios and because of the overwhelming hatred of the stock arrma radio. I got the version with the srs6000 receiver and threw it in my 6s kraton. I bined it like the manual said and made sure throttle brake reverse was all good and set steering end points. Okay. So I throw a fresh 6s pack in and go out for a bash. As soon as I got to some open space and let er rip I noticed it had way less power to it then when I was using the stock radio. I checked that my throttle setting was at 100% but that’s about all I know. Anyone have any advice or can think of what my problem is?
Also, not sure if this is the radio or the servo. It shouldn’t be because it’s a brand new savox 1210sg, this would only be the 3rd run with it. It turns fine and all but if I lift the front end off the ground ( with everything on, not moving steering or throttle) just to check out the truck after a little jump or whatever the tires just flop to right like the servo isn’t holding it steady. If that makes sense. Again, didn’t have this issue before switching to the Dx5c
