Hazmat Fury
Well I decided to do a work in progress build log to showcase some of the upgrades/repairs/modifications I make to my truck.
I love to work on things and can generally never leave anything stock.
My latest modification is the fabrication of a new multi-mount shock tower brace/shock mount for the front suspension on my Mega Fury. So here is how it went:
Using a standard shock tower brace I traced it on to some stainless steel I had lying around. As you can see here I extended the lines to make a longer mount.
I then cut it out with my Plasma Cutter - I know it is rough but it is a hand-held model not CNC (I wish).
A little time on the grinder to clean-it up. Then drilled the holes for the shock mounts.
Then I test fitted it before trimming and final shaping/clean-up of edges.
Mounted with shocks connected to new holes.
Looking straight on as it sits on the bench.
Full shock compression - no binding.
I noticed several things after putting everything back together (I had to replace servo saver).
- Ride height was lowered just a tad in the front
- Handled much better on the track
- Seemed to land better after jumps
- Took nose first landings much better
