Timmyn71
I have a Keaton 6s and hearing a popping sound when going from forward to reverse by the center diff just rebuilt and new pins and gears I’m puzzl
Usually popping or clicking is the ring gear in fr/rr diffs skipping on the pinion. Are the ring gears new? Might sound like the center diff but it's probably the rear diff. Can you take a video for me?I have a Keaton 6s and hearing a popping sound when going from forward to reverse by the center diff just rebuilt and new pins and gears I’m puzzl
Ring gear new but my input gear was stripped not my pinionUsually popping or clicking is the ring gear in fr/rr diffs skipping on the pinion. Are the ring gears new? Might sound like the center diff but it's probably the rear diff. Can you take a video for me?
Should I shim the output and if I do I'm afraid it's going to hit the diff housing my aluminum housing already has markingsRing gear new but my input gear was stripped not my pinion
srry input gear. If the input gear stripped the ring gear is toast too. Even if it was new. If it was in the case with the stripped input gear and than ran the ring gear will be damaged now. You gotta shim the lest side of the diff (ring gear side) more. Or add one shim behind input if it will let you. Buy new ring and input and re shim.Ring gear new but my input gear was stripped not my pinion
I can't shim my ring gear it just bends a shim and if I shim the output it hits the housing I have hot racing aluminum diff case no room to shimsrry input gear. If the input gear stripped the ring gear is toast too. Even if it was new. If it was in the case with the stripped input gear and than ran the ring gear will be damaged now. You gotta shim the lest side of the diff (ring gear side) more. Or add one shim behind input if it will let you. Buy new ring and input and re shim.
I have one too and yes you should be able too. So something else is up. It won't let you behind the input but it will let at least one if not 2 In the ring side.I can't shim my ring gear it just bends a shim and if I shim the output it hits the housing I have hot racing aluminum diff case no room to shim
