Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
Anytime bud. Shoot, I forgot that you put a big motor in it. It’s not just the power, it’s also the weight of the thing. Seriously, get one of the 4S differentials and input gears off of jennys and a metal diff yoke, then put them in the rear. Otherwise you may end up destroying the new composite diff fairly quickly if you’re not gentle with it. Also, go ahead and pull apart the front end and service that differential. The front stock ones will last a long time if you stay on top of them.Yes so my rear diff spur gear was eaten. It was pretty close to death but then added a kraton motor and killed in seconds. Even if I made the mesh tighter the gear was so eaten the same thing would still happen. I was expecting this someday but not so early. So um rear diff is gona ordering both new gear tomorrow. Thanks all for the help.
As I sit here, thinking about it…you may want to double think that motor man. Not only is it hard on the diffs, but also the driveshafts and the rest of the car in general. A big part of the durability of these things is keeping them lightweight. If it was a road car that’s one thing, but I believe yours is a basher. The largest can motor that I will put in my 3s cars is a 3674 in the LWB cars and 3665 in the SWB cars. I went up to 4068 in the 4s vorteks I’m building, but it has v2, 4s driveshafts, metal spur and metal differentials.
