Hi all,
I've been trying to remove the motor from my Kraton with little success. Couldn't remove it from the sliding mount and couldn't remove the pinion (I think because Arrma use red threadlock...)
So as some people suggested I bought a heat gun to loosen the stuff. I tried using a lighter first but that didn't work. I also bought some good quality MIP hex tools.
I've managed to get both the motor out and the pinion off, but I think it has come at a cost. As I was using the heat gun, the motor, ESC & centre diff became extremely hot (as in too hot to touch). I've always been careful to keep the temperature of the motor and esc cool while in use. I also saw something (I think one of the coils) inside the motor glowing for a second so I stopped using the heat gun.
Have I caused permanent damage to the motor/esc/diff?
In hindsight maybe I should have bought a butane lighter for a more controlled heat...
