Grumpy Old Man RC
Here is the setup. Arrma 6s Kraton with Proline Trencher X tires, PowerHobby 3s 7600mAh/75c/150c X 2. Stock low tooth pinion gear. The electrics are fine on heat but after a good run with as much full throttle as I can handle, the spur on the center diff was HOT! Didn’t get a temp reading so I don’t know how hot.
Anyone able to tell me a temp that I should consider too hot on the center diff/motor pinion? I have a temp gun but didn’t have it with me. Will check next time.
Gear mesh is OK per my million years of experience.
