- Kraton 6s
- Senton 6s
For your understanding, I build my own chassis 50mm longer 5mm thick and used the old chassis to make sure my holes will fit.
I ran it today on gras, which was about 8cm high. I noticed that my esc and motor got warm til hot in short time. I expected that, thanks to the weight of the chassis etc.
What I'm concerned about is the fact that my dogbones and my output shafts got hot too.
I never looked after them before, as the chassis was original. But for some reason I looked after them today, because they don't have the same play as originally. Meaning that u can't move them for 2 mm or so. There's just a bit of play, max 1mm.. I think it's less.
Is heat at the dogbone and the output shaft of the front, rear and center diff normal?
Kraton v1, front and rear standard diff oil as delivered, center got 500k in it.
