I was looking on the internet if you can harden alluminum mine is quite weak now because i unbended it a few times now. But could this be a good idea? Would like to know your opinions
50$ motor plate lelA better material would likely be the better solution. A good grade of stainless, titanium or 7075 aluminum.
With some things, paying 3-4 times more than stock is worth it when it works and lasts. Any time a part makes it stronger and less likely to cause me to wrench on it, or cut a bash session short... I'll pay the $.50$ motor plate lel
The only motor mount i found was the adjustable one from arrma and the hot racing. But they are both alluminum so..With some things, paying 3-4 times more than stock is worth it when it works and lasts. Any time a part makes it stronger and less likely to cause me to wrench on it, or cut a bash session short... I'll pay the $.
The aluminum one from Arrma is billet meaning it is a solid piece instead of cast which is melted Down into a mould, in theory it would be much stronger then stockThe only motor mount i found was the adjustable one from arrma and the hot racing. But they are both alluminum so..
Ohhhhh okiThe aluminum one from Arrma is billet meaning it is a solid piece instead of cast which is melted Down into a mould, in theory it would be much stronger then stock
