Question: Can I use header heater wrap(to run cooler) on brushless motor. 16t pinion just wanna take precautions on any heat! I'm new but wanna try new things. Not sure if someone out there tried something like that. Thank you
Ok then koo I thought there must be something better to wrap that motor. Awesome thanks for the feed back.Header Wrap is designed to hold heat in the pipes. You need just the opposite, try a heat sink with fan.
