Has anyone put heavier springs on their Mojave and if so where did you get them?
Arrma-RC.com.
Mojave Option Parts section.
I can assume you haven't been there before.
A must see for all your Mojo parts. Blow up diagrams and all.
I thought you were being a smart ass.Refresh the page.
I thought I was being informative and helpful enough.
I don't mind. Just that I go to Arrma-RC.com to help most. The info is freely available. That's what I am saying.
Where everyone else goes.
May have appeared that way. But if you know me well by now, I always get the answer as best I can. I may not be correct,,100% of the time and I will admit that and if unsure the info is always at Arrma-RC.com.
I have a Mojo, nice rig. I never changed out my springs. Running stock 6s gear. I like the stock softness of the shocks. If you have a heavier setup (8s gear), springs are available.
Dumb question, but I was hoping someone could help. I have a Mojave v2 and my son has a Senton 3S. My Mojave rolls like crazy on every sharp turn. My son's Senton is pretty tough to roll. Would a softer suspension setting or springs on the Mojave help with not rolling it as much in turns or would a harder suspension setting or springs help more? And when I say roll, I mean the car goes into a barrel roll onto its roof in sharp turns.
Wait do any of the other Arrma vehicles have option springs?Arrma-RC.com.
I'll do the work for you.
You have 6 choices of option springs.
ARRMA Radio Controlled Cars (RC Cars) - Designed Fast, Designed Tough (arrma-rc.com)
Yeah 8s gear and accessories almost require stiffer spring rates for sure.To be honest it appeared that way to me when there was no link but when you added the link I changed my post because it then appeared you were being helpful. Sorry for the misunderstanding.
I think soft suspension would help with the rolling. I’m only looking for heavier springs because I’ve added weight to my Mojave with a roll cage and 8s electronics.
I tried to tell you to refresh the page. I was searching for the kink and updated my post.
That list is sort of wrong I went over it in my post there.I found a great link here on the forum with what original spring rates are and what Arrma spring options are available.
Please accept my apology, and I will leave it at kink.
https://www.arrmaforum.com/threads/arrma-spring-list-chart-for-4s-and-most-6s-vehicles.18704/
Depends on the surface and terrain. The Mojo will roll easier. Senton 3s and Mojo have Nothing in common at all. Except the look of a SC truck body.Dumb question, but I was hoping someone could help. I have a Mojave v2 and my son has a Senton 3S. My Mojave rolls like crazy on every sharp turn. My son's Senton is pretty tough to roll. Would a softer suspension setting or springs on the Mojave help with not rolling it as much in turns or would a harder suspension setting or springs help more? And when I say roll, I mean the car goes into a barrel roll onto its roof in sharp turns.
Yeah sorry, like I said it is sort of wrong, but I guess that is totally irrelevant to this thread. Sorry I'm a little burned out tonight.Correct me if I’m wrong but based on your post aren't the Mojave numbers correct?
Yes. Mostly 6s line.Wait do any of the other Arrma vehicles have option springs?
The Mojo is top heavy because of the very heavy body. Top heavy. Learn to drive it differently than the Senton. I found there is a distinct learning curve to the Mojo and why I find it my favorite off road 6s rig right now. (v1) Never tired of driving it. High traction can be a bear to drive it. will roll easy. Just driver input to correct. I like the challenge of the Mojo personally. And never considered changing the shocks or anything about it. Still running stock 6s gear.
Having almost all the 6s rigs, the Mojo is very different by comparison. Unique the way it drives. took me a few packs to understand the weight bias etc.,
But will not get bored with it as you learn to drive it better. I feel it is one of the most durable 6s rigs. Not perfect for sure. Not a big air jumper like many get disappointed to learn. Especially if its their first rig. Arrma designed it to be driven more as a scale SC rig. That's how it should be driven.
Small jumping is great and fun. Learning its traction roll limits is fun. Just need to run it for 15 -20 packs and you will feel better connected with it.
