Could be a buckled wheel. I'd swap the wheel out and see if the problem is still there. Failing that it could be the axle/stub has bent (circled in red)
And as bicketybam has pointed out, I think that diff needs to be inspected for damage, mesh and oil level.
Physics is a hard task master and regularly teaches lessons on mechanical sympathy... normally when one lacks it. I think the car can soak up hard driving, but when hard driving becomes abuse it is time to break out the credit card and tools to fix it.
I am hoping that your problem may be a simple as buckled or loose wheel. Just took another look and I think it is more a mounting issue of the tyre to the wheel. If it is a front wheel, swap to the back and see how it goes.
Not too sure if those guys who launch cars 100' actually paid for the cars, or that the cars are stock. 100' also seems a bit of an exaggeration probably to build youtube subs/views.Someone did mention in another forum but now I'm hearing bad tire mount. I'm going to tear into the front end tonight. How common is it to wreck the diff? I'm a little pissed because I see dudes launch this thing 100' and no worries. Didn't even run half a pack they it yet
