Yep ????4s diffs are exactly the same except they use 10k stock diff oil vs. 6k stock oil used in the 3s trucks.
Thanks but do you know why there is a 49t diff and17t input aswell as a 39t diff with a 13t input gear. Thanks that helps a lot!!4s diffs are exactly the same except they use 10k stock diff oil vs. 6k stock oil used in the 3s trucks.
The 17/49 is the brushed mega version and 13/39 is the blx brushless 3/4s version. The blx brushless ones are larger and stronger so that's why they have less teeth.Thanks but do you know why there is a 49t diff and17t input aswell as a 39t diff with a 13t input gear. Thanks that helps a lot!!
I always thought the 3s diffs had 10k and 4s had the 6k in them?4s diffs are exactly the same except they use 10k stock diff oil vs. 6k stock oil used in the 3s trucks.
Thanks dude that helps a lot!! So a granite 3s diff can handle 4s however not sure about the rest of the car!?The 17/49 is the brushed mega version and 13/39 is the blx brushless 3/4s version. The blx brushless ones are larger and stronger so that's why they have less teeth.
Cheers ??The rest of it is the same as well...??
