Help getting out a stripped grub screw from outdrive
Bigtim29
Maryland, USA
  1. Notorious
  2. Talion
Before I owned mip hex drivers, I stripped out the grub screw in the out drive on my talion. Right now I have the hex head filled with epoxy with my mip driver into it. Waiting until morning for it to dry. If this does not help get the grub screw out, are their any other recommendations?
FatCatRC
FatCat Team Racing
  2. Notorious
View attachment 114433 Before I owned mip hex drivers, I stripped out the grub screw in the out drive on my talion. Right now I have the hex head filled with epoxy with my mip driver into it. Waiting until morning for it to dry. If this does not help get the grub screw out, are their any other recommendations?
flame thrower fire GIF
Ya need to heat it up and out she'll come
Jimbobjr
SE PA
  1. Kraton 8S
  3. Mojave EXB
  4. Outcast 6s
  5. Talion
  6. Typhon 6s
Maybe some heat. The locktite in there is giving you the trouble. As a last resort you could drill out the center of the screw and punch out the input shaft with a pin punch, holding the drive cup in a vise. you will need to remove the bulkhead from the car to do it though. You would just need a new drive cup.
bashingvato86
drill a hole through the grub screw with a bit that drills through metal. after that, use a stripped screw remover bit (example in link) in reverse to remove the damaged screw. good luck ??
dk3000
Central valley California
  2. Typhon 6s
  3. Typhon 3s
My recommendation is to use heat and a similar size security hex screw driver. Not saying you would have them but they grip in stripped hex screws very well. Says T8 the one I've used.
  2. Kraton EXB
  3. Mojave EXB
  4. Notorious
  5. Talion
  6. Typhon 6s
Get a torx bit so it has more contact area or a square head bit and tap it in with a hammer so it bites nice and heat it real good, it will soon come out.
3x9rtse
  1. Kraton 8S
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Talion
I see a "drill it out "and new out drive coming !!!!
Engineer
Ohio
  1. Voltage
Did you apply heat to the screw before epoxying? You really need heat to break down the red Loctite.
If that doesn’t work - then I’m with Jimbobjr’s idea of driving the input pinion out with a punch.
Twitchfast
  1. Typhon 6s
As others said, a torx bit works well.
Personally I'll go for the tightest fit, I'll go as far as to whack the bit into the stripped grub/screw to help seat it.
kratonia
https://www.homedepot.com/p/Hakko-60-Watt-Red-Soldering-Iron-503F-V12ED-P/204215957
60w soldering minium
i have both 40 and 60. 60w works best for these things.
Same at Pinions.
You need heat the red loctite before open.
Then mount it back with one drop new red loctite. let it dry over night
Minium 12h before you drive that car
Get a set of different torxes.
These are good hammer softly in when screws are stripped.
Remember buy brand new screw also to replace. Maybe two. good have one extra always ready if needed in future.
These are dirt cheap.
Bigtim29
Maryland, USA
  1. Notorious
  2. Talion
I got it out, epoxy didn’t work. I hammered in my 3mm ball tip mip driver until it fit and then heated it up with the stove.
