parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Here is what I need help looking for or a solution...
I have a led light connector on a Kyosho on-road car and using the Kyosho led lights. My issue that the receiver box has housing over it with a cut out where the wires can run out.
If I want to add lights, I need to unscrew the 2mm screw, remove the covering/housing, and pull the light connection out the receiver box. It's a pain because I cannot remove the body full since wires are connected and there is no disconnect in the wiring harness.
I would leave the cover/housing off but I cannot since the on/off switch is attached to the cover really no other place to put it
Do they make an adapter for the pic added where I can plug one end in the receiver box and other end I can plug my light harness in for easy connect and disconnect?
