Kraton Help me get the wheel pin out
Akandesh
So I've been trying to change the bearings to sealed ones and 3 wheels went super easy then the last one I had the famous issue where the small screw was super stuck so applied a bunch of heat and got it out fairly easily but the issue is that the pin doesn't move one bit. I've tried hammering on it with a small tool and heating it up with a soldering iron directly etc and nothing has worked so far. Any ideas?
Prop it up underneath the hex really well maybe even put some nuts on the hex so you don’t scar the threads! Then take either a small nail, or punch that fits on the pin and use a hammer to tappity tap it out. “BE PERSUASIVE” I’ve had luck with a 1.5mm hex driver and a hammer and a little heat right before smackin the crap out of it.👍🏻
Hmm, might have to remove the whole piece then bring it to my parents garage so I can properly hold it still then give it some heavy hammering.
