Help me purchase the right connectors?
Trevor
I’m a bit overwhelmed and looking for any help I can get.
What connectors/adaptor am I shopping for that will connect from my battery (blue) to a Granite or BRCC?
What connectors/adaptor am I shopping for that will connect from my charger (yellow) to the battery?
The blue end is called a ec5... it should directly plug into the arrma esc with factory plugs, even if it's the new ic5...
So for your charger your looking for ec5 to 4mm banana
Or if you plan to keep the plug on the charger (xt60) you need an adaptor from xt60 to ec5... but I would just buy a ec5 to 4mm banana if you have to purchase stuff anyways
This
https://www.amazon.com/Adapter-KCRT...=2025&creative=165953&creativeASIN=B07BHHTPZ2
Check to make sure you need the correct male or female. I usually solder mine up as needed, but like @Camaroboy383 said it would be better to get the 4mm bullet/ EC5 adapter for the charger. I don't like connecting adapters to more adapters. That equals more resistance and goes against the rules...but charging rates usually low and you can get away with it.
But never use adapters between the ESC and your lipo if you don't know that already.
I have an ec5 charging lead. I’m not looking to turn a huge profit on it, if you’re looking for one private message me. Not that it matters but it’s never even been used.
Last question (I hope).
What connector would I need to make this work? I’m thinking about picking up a pair of these (2S) to keep us from going crazy on 3S as we adjust to the speed of these cars.
You will need to unsolder the deans connector and solder EC5 connector the blue we said earlier
They are pretty easy to solder i think i have xt90's and its like cake
Looks like I can order a T Male to EC5 Female adapter for the 2S battery without soldering. I’ll try that first and then head out to the LHS about soldering. I live in a small house and I don’t think I’d use a soldering iron often enough to justify the purchase.
I don’t know man. A lot of adapters are for charging use only. That’s totally fine, just don’t try and run them in a vehicle. Under high amp draw, especially if it’s a cheap job, it’ll melt and possibly short out.
That makes sense. Looks like the only true answer here is to learn how to solder.
If I’m ordering on Amazon, do I need anything else besides a soldering iron and several of the EC5 connectors? Anything else I should order while I’m online?
Some quality solder and flux. Ask around for that stuff though. My equipment isn’t the best.
