Evildoublez
I recently installed a new servo on my Arrma Talion 6s. In order to do so I had to remove the ESC and rerun all the wiring. After putting it all back together I turned it on and tested the steering. Everything seemed to be working fine. When I took it outside and tried to take it for a spin in the parking lot the ESC burst into flames. I obviously shorted it out somehow... but how? Any idea what would make this happen? The fire started when I drove it through a little bit of water, if that matters (although it shouldn't).
Also, since I'm going to need a new ESC can anyone recommend an upgrade? I'm not looking to spend a lot of extra money so cost is a big factor.
Thanks in advance!
Thanks in advance!
