RC617
So when running my Kraton 6s V5 yesterday I noticed that when letting off the throttle and off steering the front tires "steered" sided to side fairly quickly. It was like I was quickly cranking the steering wheel back and forth. When on throttle and actively giving it steering input it appeared not to be a problem. I initially though something was loose in the front chassis/steering system, however I took the tires off and checked everything and retightened everything and didn't notice any abnormal play. So this morning I gave it a go again, and it was still the same. I would run it up to high speeds and then let it coast and the side-to-side steering was very pronounced. Again if I gave it steering input it seemed to clean it up. It's almost like when no steering input is given it acts like the steering is disconnected (or the servo is self steering), however with the vehicle on and no steering input I tried to see if there was looseness or wobble in the system but it feels fairly tight and I can feel resistance from the servo. So I'm at a loss as to where the problem may be and would appreciate any thoughts.
