parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
I may be comparing apples to oranges but I need little advice on the drift action on the Felony in comparison to my Infraction v1...
Although I am new at the hobby, I have gotten tons better throttle with throttle control. So much so, I can point the Infraction v1 where I want it hit my cone turns & points and bring it back to where I want it. The Infraction v1 is running white Hoons and 60/100/30 f/c/r diffs. Speed runs are not my thing never will be. What I like about the Infraction as it is now, I can hook turns wide or shape at throttle and it forward pulls perfectly out the slide/drift and goes EXACTLY in the direction I point it in. It's not overturning in the slide and I have and can feel control.
Felony
It is stock like the Infraction v1 no changes to the Felony outside of matching the diffs to 60/100/30 and shimming the slop in the wheels/balanced tires etc...exact same as the Infraction. In the example above, when I hook the Felony in a wide or tight slide or drift the backend keeps sliding around. The back end will slide around in a slow turn at times. However on throttle if I tried what I explained above with the Infraction, the Felony will spin around or overspin coming out the drift. I do not have the control in the turns and spins with the Felony as I do with the Infraction v1.
What am I missing or doing wrong:
Any advice
Felony
- Mind you I have only run it twice
- Is it AVC... I have played with it tried to set it about where the Infraction is located and other adjustments
- Is it diff... do I need to try a different setup to reduce the rear sliding...if so what
- Tires maybe.... rear tires creating this spin-out or just the nature of the Felony
- Something else I am missing all together
Any advice
