- Granite
Hi guys, I need some advise with this. I have a brand new Castle motor and esc. When I installed it into my truck I noticed it the tires jammed when I tried to roll it. I couldnt figure out the issue until I examined the pinion gear and realized it's not centered on the pole of the motor correctly. When I tighten the screw it clearly pushes the gear to one side, I can't imagine this company would design something with this big of a design flaw. Here's some pics attached. Am I supposed to put something else in the pinion gear so this doesn't happen?
Now that I'm looking at it, I'm starting to wonder if the pinion gear that came with the truck is designed for a different motor altogether?
