HELP!! Stripped screw head
So I’m checking the center diff fluid before running my new rig and I stripped a screw head trying several methods to remove it. I think it’s probably got too much loctite from the factory. Any suggestions for removing it? The other three are loose and I had no trouble with the rear diff.
I USED JB Weld 2 part epoxy, set a Allen key in that fits the tightest, then I epoxied the key to the screw, next morning I backed it right out, this only works if you have the time, and you will need a replacement screw.
Thank you. That surely is a unique approach! I guess I should have specified that I did get the screw out already. I bought a screw extractor and did it that way. Thanks for your suggestion. 👊🏻
This is what I use to get stripped screws out, it hasn't failed me yet! I think it a must have.
