djp5690
- Points
- 103
- Granite Grom
- Mojave
- Mojave Grom
- Typhon 6s
- Typhon Mega
I’m pretty new to building bigger stuff from the ground up. Managed to find a chassis I like, motor, drive shaft, looking for an ESC…. Allllll that good stuff now…. I’m stuck! What tires do I order for these?? They’re ~6mm, there’s a hole to drop a pin through the hex nut.
So far I have ordered these, with an inside diameter of 8mm or so (way too big, and I set of tires with an ID of 5mm (too small). Anyone have a suggestion fit what I’m failing to figure out??? Insight greatly appreciated!!!! Thanks so much!
