But wouldn’t the heat of the motor affect it? I’m not sure how hot the servo gets I’m sure it’s way less than the motor, also I believe in top of the servo will pass more air but still not surePut it next to receiver box behind motor. Or if wires will reach other side of truck
Yeah I know but I’m having issues with overheat it shuts down every time I use it ?Cooling shouldnt be a concern on the mega line unless you changed the pinion to a larger tooth count... I personally would mount it down in the tub like stated above...I hate the receiver box mount points...
Get a heatsink and fan for the motor. Keep the motor cooler will help the esc stay cooler and help save the motor from burning up. The esc heats up because the motor runs hot.
yeah I’m looking for one on eBay but this would be a temporary solution to try and get a few extra minutes before it shuts down for overheat
I have two batteries at this point the original 8.4v and another one same capacity 2,400 mah 7.2 that came with a fast charger, the og one last about 10 minutes and other one last about 12-15 minutes but with the original one it shuts down about 8 minutes run, the 7.2 battery is almost empty when I charge it back up but the original one always have some juice left I there, weird thing is it’s all stock gearing I haven’t change anything, I’m worried about cooling because I ordered a 4,200 mag 8.4v battery and it should be here in two days? that's crazy, how long does it run before it shuts down? The factory battery only lasts about 5min..
Yeah I actually cleaned and lubed all 8 bearings in the wheels, I haven’t checked the bearings located inside the differentials but i don’t think those ones need as much maintenance, the ones connecting the slipper clutch and both differentials on the outside are fine as well, I blow the engine up with compressed air after a couple of bash sessions as well to make sure it’s clean and put some 3in1 oil in the engine bearingsHave you checked all the drivetrain to make sure there is no binding, and all is running freely?
Yep is on NiMh both batteries are NiMh including the bigger one that is on the wayDo you have the jumper set to NiMH for the OG one?
Get a fan with a holderBut wouldn’t the heat of the motor affect it? I’m not sure how hot the servo gets I’m sure it’s way less than the motor, also I believe in top of the servo will pass more air but still not sure
