alexworkman
Hi, I was wondering if anyone could help.
i have a spektrum firma 130 amp esc. It turns off the moment you give throttle. I was running it in a parking lot and it just shut off. I open it up to discover that everything was properly connected. I turned it back on and the steering works properly but the moment you give throttle input it just shuts off. I reset the esc and recalibrated it and it still does the same thing. I check the battery connections and voltages put a fresh pack in and the same issue still persists.
i will attach a video shortly. Thank you in advance.
