So now that my kraton exb 6s actually runs without striping diffs, which I believe was at fault of the diff case being casted wrong or something, I now have the issue of gearing, I couldn’t get through a battery pack as everything was way way to hot, I’m running a hobby wing max 6 with a 4985 1650kv motor, zee 6s 6000mah batts, and 18t pinion, and whatever is stock on the kraton exb 6s for spur, what gearing do you guys recommend? As with a 18 it’s just way way to hot and I don’t wanna wreck my motor or esc
