On my Max6 1650kv combo I started with a 20 tooth gear and it was much too hot to touch. I then began steeping down to a 19T then a 17T but the motor was still too hot to touch. I finally decided to add dual 40MM Powerhobby Twister fans and this Powerhobby 47-49mm motor mount.
Just yesterday I was running it in 100F weather in the grass and the motor was barely warm after putting two or more batteries through it.
P.S. That Powerhobby motor mount is the only mount I could find that fits the 1650Kv motor. You can purchase the mount on ebay as well but since I was already purchasing the fans direct from Power Hobby I added the mount to my order.
Do you need 3x of those motor mounts? One in the middle and one at each end of the 2x fan setup?
