Disconnect the servo from the receiver and see if the fan runs again. If so, the servo probably died and is messing with things. Even better would be to plug another servo in and test it.Was running fine, left it sit for 5mins while I ran inside to get a drink. Came back out and the steering wouldn’t work. The fan quits when you try to turn, has throttle. Any suggestions?
