Help with my granite
The diff is not normally ordered as an assembly - you order the gears are are broken. Either the outdrives, or the planetary gears, or the ring/case gear. There are probably 3 screws in the side of the diff to open it up and look at the gears inside.
Edit - After looking at the exploded view, it looks like the Voltage diff is sold as an assembly. Cool. Part # AR310765
https://www.arrma-rc.com/pdf/exploded-views/AR102663.pdf
Ya I found it as the assembly just wanted to make sure that was the issue. I didn't see anything else but just wanted to make sure. I did find a screw on both sides of the diff. I just didn't know if it came apart. I wasn't sure as I didn't see any seem. Thanks to everyone for all the help and input
