Kraton Help with spur gear.
OG*GOBLIN
North Jersey
  2. Kraton EXB
I picked up a 46t spur gear and went to put it on the center diff I got from Jenny's but it's different on the inside. Did I order the wrong parts or am I missing something? If that diff is the same as my EXB it won't work with that one either correct? Spur gear is part#ara310939
Drop the whole v4 diff in if you want to run the 46t spur. I was curious of the older spur fit the new exb cup but figured i'd just run an open diff there. I always run 1m diff fluid in the center of my rigs anyways.
I don't currently have a v4 diff assembly. Need to order the off-road spur gear for the v5
