Granite Help with suspension setup
Bmay
I've got the hot racing shock bodies in and the gpm tower braces. Put in 50w shock oil.
Surprised I had to raise the back so high to get it leveled. Anybody else have this setup? Any pointers on tuning it?
Could be you mixed the front springs with the rears when you assembled the hot racing shocks?
Only if they were packaged wrong. I did the fronts weeks ago and the rear last night
Maybe you mounted the shocks on the inner hole on the rear a-arm? instead of the outer?
i have the same shocks on my granite, I have a little less preload on the rear, but much more than you on the front.
Thanks. They are on the outer in the back too. Difference must be in the tower braces on mine. Could experiment with moving those in
