I installed a flysky gt5 radio and transmitter but the truck keeps pulling pretty bad to the right. how do I adjust the trim on it and what needs to be adjusted in the trim? is there a right and left trim setting on it?
yes, okay thank you!Is this the radio you have?
https://www.amazon.com/Flysky-FS-GT...b937c0d6f89ffc9dafaecfe&qid=1588315571&sr=8-1
If so, it appears that you have the steering trim buttons near the throttle trigger. Zero that out as suggested by @Slevin (your radio should indicate what your trim is currently set to when you try to adjust that trim either way) and see where your wheels are pointing when at zero.
If they are way off, remove the servo horn, straighten our your wheels as much as possible, and reinstall the servo horn. Then, fine tune with your steering trim.
Hope this helps.
